https://forum.helios.eu:443/orange/doc/cs/Vzory_platebn%C3%ADch_p%C5%99%C3%ADkaz%C5%AF_zahrani%C4%8Dn%C3%ADch_-_Banka
O:\download\doc\wiki\Vzory_platebn%C3%ADch_p%C5%99%C3%ADkaz%C5%AF_zahrani%C4%8Dn%C3%ADch_-_Banka
