https://forum.helios.eu:443/orange/doc/cs/V%C3%BDkaz_podle_z%C3%A1kona_o_povinn%C3%A9m_zna%C4%8Den%C3%AD_lihu_-_Poradna_(CZ)
O:\download\doc\wiki\V%C3%BDkaz_podle_z%C3%A1kona_o_povinn%C3%A9m_zna%C4%8Den%C3%AD_lihu_-_Poradna_(CZ)
