https://forum.helios.eu:443/orange/doc/cs/Pokladn%C3%AD_prodej_-_Zm%C4%9Bny_2018
O:\download\doc\wiki\Pokladn%C3%AD_prodej_-_Zm%C4%9Bny_2018
