https://forum.helios.eu:443/orange/doc/cs/Podm%C3%ADnky_pro_implementaci_modulu..._-_P%C5%99epravn%C3%AD_slu%C5%BEby
O:\download\doc\wiki\Podm%C3%ADnky_pro_implementaci_modulu..._-_P%C5%99epravn%C3%AD_slu%C5%BEby
