https://forum.helios.eu:443/orange/doc/cs/P%C5%99%C3%ADklad_zad%C3%A1n%C3%AD_pl%C3%A1novan%C3%BDch_hodnot_-_Finan%C4%8Dn%C3%AD_anal%C3%BDza_a_pl%C3%A1nov%C3%A1n%C3%AD
O:\download\doc\wiki\P%C5%99%C3%ADklad_zad%C3%A1n%C3%AD_pl%C3%A1novan%C3%BDch_hodnot_-_Finan%C4%8Dn%C3%AD_anal%C3%BDza_a_pl%C3%A1nov%C3%A1n%C3%AD
