https://forum.helios.eu:443/orange/doc/cs/Nov%C3%A1_sestava_gener%C3%A1toru_-_%C3%9A%C4%8Detnictv%C3%AD
O:\download\doc\wiki\Nov%C3%A1_sestava_gener%C3%A1toru_-_%C3%9A%C4%8Detnictv%C3%AD
