https://forum.helios.eu:443/orange/doc/cs/Inventury_nedokon%C4%8Den%C3%A9_v%C3%BDroby_-_V%C3%BDroba
O:\download\doc\wiki\Inventury_nedokon%C4%8Den%C3%A9_v%C3%BDroby_-_V%C3%BDroba
