https://forum.helios.eu:443/orange/doc/cs/Intrastat_-_zpracov%C3%A1n%C3%AD_m%C4%9Bs%C3%AD%C4%8Dn%C3%ADho_hl%C3%A1%C5%A1en%C3%AD_za_m%C4%9Bs%C3%ADc_prosinec_2013
O:\download\doc\wiki\Intrastat_-_zpracov%C3%A1n%C3%AD_m%C4%9Bs%C3%AD%C4%8Dn%C3%ADho_hl%C3%A1%C5%A1en%C3%AD_za_m%C4%9Bs%C3%ADc_prosinec_2013
