https://forum.helios.eu:443/orange/doc/cs/Import_deklarac%C3%AD_z_programu_CLA_pro_DOS_-_Celn%C3%AD_p%C5%99%C3%ADpady
O:\download\doc\wiki\Import_deklarac%C3%AD_z_programu_CLA_pro_DOS_-_Celn%C3%AD_p%C5%99%C3%ADpady
