https://forum.helios.eu:443/orange/doc/cs/Helios_Easy:Bankovn%C3%AD_v%C3%BDpisy_-_Banka
O:\download\doc\wiki\Helios_Easy:Bankovn%C3%AD_v%C3%BDpisy_-_Banka
