https://forum.helios.eu:443/orange/doc/cs/Funkce_gener%C3%A1toru_%C3%BA%C4%8Detn%C3%ADch_sestav_-_%C3%9A%C4%8Detnictv%C3%AD
O:\download\doc\wiki\Funkce_gener%C3%A1toru_%C3%BA%C4%8Detn%C3%ADch_sestav_-_%C3%9A%C4%8Detnictv%C3%AD
