https://forum.helios.eu:443/orange/doc/cs/Faktur%C3%A1cia_a_po%C5%A1ta_(SK)_-_Zm%C4%9Bny_2009
O:\download\doc\wiki\Faktur%C3%A1cia_a_po%C5%A1ta_(SK)_-_Zm%C4%9Bny_2009
