https://forum.helios.eu:443/orange/doc/cs/Elektronick%C3%A1_fakturace_ISDOC_-_Zm%C4%9Bny
O:\download\doc\wiki\Elektronick%C3%A1_fakturace_ISDOC_-_Zm%C4%9Bny
