https://forum.helios.eu:443/orange/doc/cs/Dohadn%C3%A9_polo%C5%BEky_na_dovolenou_-_Mzdy_(CZ)
O:\download\doc\wiki\Dohadn%C3%A9_polo%C5%BEky_na_dovolenou_-_Mzdy_(CZ)
