https://forum.helios.eu:443/orange/doc/cs/Do%C5%A1l%C3%A9_objedn%C3%A1vky_-_Detail_zaji%C5%A1t%C4%9Bn%C3%AD_-_Ob%C4%9Bh_zbo%C5%BE%C3%AD
O:\download\doc\wiki\Do%C5%A1l%C3%A9_objedn%C3%A1vky_-_Detail_zaji%C5%A1t%C4%9Bn%C3%AD_-_Ob%C4%9Bh_zbo%C5%BE%C3%AD
