https://forum.helios.eu:443/orange/doc/cs/Definice_%C5%99%C3%A1dku_v%C3%BDkazu_-_V%C3%BDkazy
O:\download\doc\wiki\Definice_%C5%99%C3%A1dku_v%C3%BDkazu_-_V%C3%BDkazy
