https://forum.helios.eu:443/orange/doc/cs/Datov%C3%BD_sklad_-_definice_-_Finan%C4%8Dn%C3%AD_anal%C3%BDza_a_pl%C3%A1nov%C3%A1n%C3%AD
O:\download\doc\wiki\Datov%C3%BD_sklad_-_definice_-_Finan%C4%8Dn%C3%AD_anal%C3%BDza_a_pl%C3%A1nov%C3%A1n%C3%AD
