https://forum.helios.eu:443/orange/doc/cs/Coln%C3%BD_sklad_(SK)_-_Zm%C4%9Bny_2015
O:\download\doc\wiki\Coln%C3%BD_sklad_(SK)_-_Zm%C4%9Bny_2015
